Saltar al contenido principal
Introducción
Remove and Replace the Hard Drive
Herramientas
No se especificaron herramientas.
Partes
No se especificaron partes.
  1. Make sure the computer is turned off, by selecting the start menu and choosing “Shut Down”.
    • Make sure the computer is turned off, by selecting the start menu and choosing “Shut Down”.
    • Ensure all cables, speakers and other devices are unplugged and turned off before opening the computer case.
  2. Lay the computer on its side; you will see a blue knob. Turn this knob 90 deg clockwise.
    • Lay the computer on its side; you will see a blue knob.
    • Turn this knob 90 deg clockwise.
  3. Slide the panel case forward about 1/2 inch while knob is turned. Lift panel case off computer.
    • Slide the panel case forward about 1/2 inch while knob is turned.
    • Lift panel case off computer.
  4. Kits de reparación de iPhone X
    ¿Garantía vencida? No te preocupes, tenemos la solución.
    Comprar Ahora
    Comprar Ahora
  5. Unplug the blue cable that connects the hard drive to the motherboard. Unplug the blue cable that connects the hard drive to the motherboard.
    • Unplug the blue cable that connects the hard drive to the motherboard.
  6. Unplug the power supply, distinguished by its red and yellow wires (yellow wire obscured from view). Unplug the power supply, distinguished by its red and yellow wires (yellow wire obscured from view).
    • Unplug the power supply, distinguished by its red and yellow wires (yellow wire obscured from view).
  7. Squeeze the release tabs on either side of the hard drive.
    • Squeeze the release tabs on either side of the hard drive.
  8. Slide the Hard Drive out while squeezing the tabs. Slide the Hard Drive out while squeezing the tabs.
    • Slide the Hard Drive out while squeezing the tabs.
Conclusión
6 personas más completaron esta guía.
Wyatt
Miembro Desde 06/10/10
742 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 22-4, Maness Fall 2010 Miembro de Cal Poly, Team 22-4, Maness Fall 2010
CPSU-MANESS-F10S22G4
4 Miembros
13 Guías creadas
Thanks for great tutorial.
Politers - Contestar
Yeah great tutorial!
Rebinas - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 4
Todo El Tiempo: 5,478
