Saltar al contenido principal
Introducción
To access all other parts, you must first remove the cover.
Herramientas
No se especificaron herramientas.
Partes
No se especificaron partes.
  1. Power down your PC and remove the power cord from the back. Power down your PC and remove the power cord from the back.
    • Power down your PC and remove the power cord from the back.
  2. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  3. Press and hold the power button for about 10 seconds, then release. This helps drain any remaining power stored in the capacitors, so that you can safely work on the internal components.
    • Press and hold the power button for about 10 seconds, then release.
    • This helps drain any remaining power stored in the capacitors, so that you can safely work on the internal components.
  4. With the computer standing upright, firmly pull on the tab at the back of the computer.
    • With the computer standing upright, firmly pull on the tab at the back of the computer.
    • When the side panel pops free, gently pull the panel away from the computer.
    • If you have trouble freeing the side panel from the case, you may need to pull the tab a bit harder.
Conclusión
5 personas más completaron esta guía.
Kristina
Miembro Desde 03/09/14
144 Reputación
7 Guías creadas
Equipo
Pasco Hernando, Team 5-1, Prince Fall 2014 Miembro de Pasco Hernando, Team 5-1, Prince Fall 2014
PHSC-PRINCE-F14S5G1
10 Miembros
8 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 26
Últimos 30 Días: 105
Todo El Tiempo: 4,646
