Saltar al contenido principal
Introducción
RAM should be replaced if the computer has memory issues. This is sometimes the case when the computer won't boot, or simply runs too slow for comfort.
Partes
No se especificaron partes.
  1. Power down your PC and remove the power cord from the back. Power down your PC and remove the power cord from the back.
    • Power down your PC and remove the power cord from the back.
  2. Press and hold the power button for about 10 seconds, then release. This helps drain any remaining power stored in the capacitors, so that you can safely work on the internal components.
    • Press and hold the power button for about 10 seconds, then release.
    • This helps drain any remaining power stored in the capacitors, so that you can safely work on the internal components.
  3. With the computer standing upright, firmly pull on the tab at the back of the computer.
    • With the computer standing upright, firmly pull on the tab at the back of the computer.
    • When the side panel pops free, gently pull the panel away from the computer.
    • If you have trouble freeing the side panel from the case, you may need to pull the tab a bit harder.
  4. Using the tips of your fingers, press out the securing clips on both sides of the memory modules.
    • Using the tips of your fingers, press out the securing clips on both sides of the memory modules.
  5. To remove the memory, pull straight up on the module.
    • To remove the memory, pull straight up on the module.
Conclusión
5 personas más completaron esta guía.
Kristina
Miembro Desde 03/09/14
144 Reputación
7 Guías creadas
Equipo
Pasco Hernando, Team 5-1, Prince Fall 2014 Miembro de Pasco Hernando, Team 5-1, Prince Fall 2014
PHSC-PRINCE-F14S5G1
10 Miembros
15 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 3
Últimos 30 Días: 16
Todo El Tiempo: 1,631
