Saltar al contenido principal
Dell Optiplex GX620 RAM Replacement
Qué necesitas
  1. Dell Optiplex GX620 RAM Replacement, How to unplug and discharge before repair: paso 1, imagen 1 de 2 Dell Optiplex GX620 RAM Replacement, How to unplug and discharge before repair: paso 1, imagen 2 de 2
    • Power down your PC and remove the power cord from the back.
  2. Dell Optiplex GX620 RAM Replacement: paso 2, imagen 1 de 2 Dell Optiplex GX620 RAM Replacement: paso 2, imagen 2 de 2
    • Press and hold the power button for about 10 seconds, then release.
    • This helps drain any remaining power stored in the capacitors, so that you can safely work on the internal components.
  3. Dell Optiplex GX620 RAM Replacement, Dell Optiplex GX620 Side Panel Disassembly: paso 3, imagen 1 de 1
    • With the computer standing upright, firmly pull on the tab at the back of the computer.
    • When the side panel pops free, gently pull the panel away from the computer.
    • If you have trouble freeing the side panel from the case, you may need to pull the tab a bit harder.
  4. Dell Optiplex GX620 RAM Replacement, Press the clips: paso 4, imagen 1 de 1
    • Using the tips of your fingers, press out the securing clips on both sides of the memory modules.
  5. Dell Optiplex GX620 RAM Replacement, Remove the memory: paso 5, imagen 1 de 1
    • To remove the memory, pull straight up on the module.
Conclusión
6 personas más completaron esta guía.
Kristina
Miembro Desde 09/03/14
210 Reputación
7 Guías creadas
Equipo
Pasco Hernando, Team 5-1, Prince Fall 2014 Miembro de Pasco Hernando, Team 5-1, Prince Fall 2014
PHSC-PRINCE-F14S5G1
10 Miembros
15 Guías creadas
Un comentario
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 12
Ultimos 30 días: 36
Todo El Tiempo: 2,564
