Saltar al contenido principal
Dell Optiplex 745 Ultra Small Form Factor CPU Replacement
Qué necesitas
  1. Dell Optiplex 745 Ultra Small Form Factor CPU Replacement, Side Panel: paso 1, imagen 1 de 1
    • Make sure to shut down the computer! Go to the start menu and click shutdown from the power options first
    • Ensure all cables, speakers and other devices are unplugged and turned off before opening the computer case.
  2. Dell Optiplex 745 Ultra Small Form Factor CPU Replacement: paso 2, imagen 1 de 1
    • Lay the computer on its side; you will see a blue knob.
    • Turn said knob 90 degrees counter clockwise.
  3. Dell Optiplex 745 Ultra Small Form Factor CPU Replacement: paso 3, imagen 1 de 1
    • While the knob is still turned, slide the panel case forward about 1/2 inch, and then lift the panel off the computer.
  4. Dell Optiplex 745 Ultra Small Form Factor CPU Replacement, CPU Heat Sink: paso 4, imagen 1 de 2 Dell Optiplex 745 Ultra Small Form Factor CPU Replacement, CPU Heat Sink: paso 4, imagen 2 de 2
    • Remove the blue shield by sliding it straight upwards.
  5. Dell Optiplex 745 Ultra Small Form Factor CPU Replacement: paso 5, imagen 1 de 3 Dell Optiplex 745 Ultra Small Form Factor CPU Replacement: paso 5, imagen 2 de 3 Dell Optiplex 745 Ultra Small Form Factor CPU Replacement: paso 5, imagen 3 de 3
    • Pull back on the tab nearest to the front case fan.
    • Slide the CPU heat sink from under the clip and pull upward.
    • You may need to twist the CPU heat sink side to side to free it from the thermal paste.
  6. Dell Optiplex 745 Ultra Small Form Factor CPU Replacement, CPU: paso 6, imagen 1 de 2 Dell Optiplex 745 Ultra Small Form Factor CPU Replacement, CPU: paso 6, imagen 2 de 2
    • Ground yourself before removing any internal components.
    • Push release lever down slightly and away from CPU.
  7. Dell Optiplex 745 Ultra Small Form Factor CPU Replacement: paso 7, imagen 1 de 2 Dell Optiplex 745 Ultra Small Form Factor CPU Replacement: paso 7, imagen 2 de 2
    • Lift and rotate processor cover off of CPU.
    • Processor cover will remain attached.
  8. Dell Optiplex 745 Ultra Small Form Factor CPU Replacement: paso 8, imagen 1 de 1
    • Using two fingers holding the sides, lift the CPU from the socket.
    • Do not touch the underside of the CPU or any of the pins.
    • When replacing the CPU, do not use excessive force.
    • Ensure to use the alignment-notches on the new CPU, when replacing.
Conclusión
Una persona más ha completado esta guía.
donnavon
Miembro Desde 09/02/14
707 Reputación
7 Guías creadas
Equipo
Pasco Hernando, Team 1-1, Prince Fall 2014 Miembro de Pasco Hernando, Team 1-1, Prince Fall 2014
PHSC-PRINCE-F14S1G1
11 Miembros
14 Guías creadas
Un comentario
What Cpu does it use?
Jazelle Estrada - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 18
Todo El Tiempo: 2,162
