Saltar al contenido principal
Dell Optiplex 745 Small Form Factor Rear Audio Jack Replacement
Guía Archivada
Esta guía se mantiene únicamente para fines históricos. Utiliza la última versión de la guía para llevar a cabo tu reparación.
Qué necesitas
  1. Dell Optiplex 745 Small Form Factor Rear Audio Jack Replacement, side panels: paso 1, imagen 1 de 3 Dell Optiplex 745 Small Form Factor Rear Audio Jack Replacement, side panels: paso 1, imagen 2 de 3 Dell Optiplex 745 Small Form Factor Rear Audio Jack Replacement, side panels: paso 1, imagen 3 de 3
    • Remove the side panel/cover
    • Pull the slide at the top back.
    • This releases the panel, and it can be removed easily.
  2. Dell Optiplex 745 Small Form Factor Rear Audio Jack Replacement, Remove the back cover.: paso 2, imagen 1 de 3 Dell Optiplex 745 Small Form Factor Rear Audio Jack Replacement, Remove the back cover.: paso 2, imagen 2 de 3 Dell Optiplex 745 Small Form Factor Rear Audio Jack Replacement, Remove the back cover.: paso 2, imagen 3 de 3
    • Remove the back cover.
    • Unscrew the 3 screws at the back, next to the power cable slot.
    • Pull along the sides of the cover bit by bit to remove each holder from its respective slot
  3. Dell Optiplex 745 Small Form Factor Rear Audio Jack Replacement, Rear Audio Jack: paso 3, imagen 1 de 1
    • Upon opening the desktop, locate the rear audio jacks.
  4. Dell Optiplex 745 Small Form Factor Rear Audio Jack Replacement: paso 4, imagen 1 de 1
    • Once located, identify the soldering points that connect the audio jacks to the motherboard.
    • There is another location you cannot see in the picture which is a part of the rectangular pattern.
    • Gently apply the soldering iron to these points to loosen the hold on the audio jacks.
    • Applying the soldering iron for extended periods of time will damage your device. So it is best to cycle from point to point, slowly trying to remove the audio jacks little by little.
Conclusión
Jeremy Nicholas
Miembro Desde 10/09/17
228 Reputación
2 Guías creadas
Equipo
USF Tampa, Team S5-G5, Walkup Fall 2017 Miembro de USF Tampa, Team S5-G5, Walkup Fall 2017
USFT-WALKUP-F17S5G5
Miembros de 4
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 353
