Saltar al contenido principal
Dell Optiplex 745 Small Form Factor RAM Replacement
  1. Dell Optiplex 745 Small Form Factor RAM Replacement, Opening the case: paso 1, imagen 1 de 2 Dell Optiplex 745 Small Form Factor RAM Replacement, Opening the case: paso 1, imagen 2 de 2
    • Pull the tab and the lid will pop up.
  2. Dell Optiplex 745 Small Form Factor RAM Replacement: paso 2, imagen 1 de 2 Dell Optiplex 745 Small Form Factor RAM Replacement: paso 2, imagen 2 de 2
    • Grab the lid and pull it up and off.
  3. Dell Optiplex 745 Small Form Factor RAM Replacement, Disconnecting the cables: paso 3, imagen 1 de 2 Dell Optiplex 745 Small Form Factor RAM Replacement, Disconnecting the cables: paso 3, imagen 2 de 2
    • Pull out both sets of cables from the side of the optical drive.
    • Both cables are plugged into the drive right next to each other.
  4. Dell Optiplex 745 Small Form Factor RAM Replacement, Removing the optical drive: paso 4, imagen 1 de 2 Dell Optiplex 745 Small Form Factor RAM Replacement, Removing the optical drive: paso 4, imagen 2 de 2
    • Pull the tab up holding the optical drive in place.
    • Slide the optical drive out.
  5. Dell Optiplex 745 Small Form Factor RAM Replacement, Unlocking the RAM stick from the motherboard: paso 5, imagen 1 de 2 Dell Optiplex 745 Small Form Factor RAM Replacement, Unlocking the RAM stick from the motherboard: paso 5, imagen 2 de 2
    • Press down on the white tabs on both sides of the RAM stick until the RAM stick pops up.
  6. Dell Optiplex 745 Small Form Factor RAM Replacement, Lifting the RAM stick out of the case: paso 6, imagen 1 de 1
    • Gently lift the RAM stick up and out of the case.
    • When inserting a RAM stick, press firmly down into the slot until the white tabs lock into both sides of the stick.
Conclusión
7 personas más completaron esta guía.
Brandon Cooper
Miembro Desde 09/28/14
480 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 13-10, Forte Fall 2014 Miembro de Cal Poly, Team 13-10, Forte Fall 2014
CPSU-FORTE-F14S13G10
6 Miembros
12 Guías creadas
Un comentario
Dell master. I'm going to be the best repair pro on this side of the south side.
fixitbrosmsus - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 17
Todo El Tiempo: 1,694
