Saltar al contenido principal
Dell Optiplex 745 Small Form Factor Processor Replacement
Qué necesitas
  1. Dell Optiplex 745 Small Form Factor Processor Replacement, Opening the case: paso 1, imagen 1 de 2 Dell Optiplex 745 Small Form Factor Processor Replacement, Opening the case: paso 1, imagen 2 de 2
    • Pull the tab and the lid will pop up.
  2. Dell Optiplex 745 Small Form Factor Processor Replacement: paso 2, imagen 1 de 2 Dell Optiplex 745 Small Form Factor Processor Replacement: paso 2, imagen 2 de 2
    • Grab the lid and pull it up and off.
  3. Dell Optiplex 745 Small Form Factor Processor Replacement, Processor: paso 3, imagen 1 de 1
    • The processor is located inside the heat sink (indicated by the marker).
  4. Dell Optiplex 745 Small Form Factor Processor Replacement: paso 4, imagen 1 de 3 Dell Optiplex 745 Small Form Factor Processor Replacement: paso 4, imagen 2 de 3 Dell Optiplex 745 Small Form Factor Processor Replacement: paso 4, imagen 3 de 3
    • Unscrew the 9.5 mm screws from heatsink on both sides using the Phillips #2 screwdriver.
    • If the processor is glued on to the heat sink, gently scrape off the glue and detach it from the device.
  5. Dell Optiplex 745 Small Form Factor Processor Replacement: paso 5, imagen 1 de 3 Dell Optiplex 745 Small Form Factor Processor Replacement: paso 5, imagen 2 de 3 Dell Optiplex 745 Small Form Factor Processor Replacement: paso 5, imagen 3 de 3
    • Push the small lever downwards, then sideways and upwards, in order to release it from the hook.
    • Remove the processor from its casing.
Conclusión
3 personas más completaron esta guía.
Abdullah Khan
Miembro Desde 10/03/17
181 Reputación
1 Guía escrita
Equipo
USF Tampa, Team S5-G5, Walkup Fall 2017 Miembro de USF Tampa, Team S5-G5, Walkup Fall 2017
USFT-WALKUP-F17S5G5
Miembros de 4
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 12
Todo El Tiempo: 1,353
