Saltar al contenido principal
Dell Optiplex 745 Small Form Factor Power Supply Replacement
Qué necesitas
  1. Dell Optiplex 745 Small Form Factor Power Supply Replacement, Opening the case: paso 1, imagen 1 de 2 Dell Optiplex 745 Small Form Factor Power Supply Replacement, Opening the case: paso 1, imagen 2 de 2
    • Pull the tab and the lid will pop up.
  2. Dell Optiplex 745 Small Form Factor Power Supply Replacement: paso 2, imagen 1 de 2 Dell Optiplex 745 Small Form Factor Power Supply Replacement: paso 2, imagen 2 de 2
    • Grab the lid and pull it up and off.
  3. Dell Optiplex 745 Small Form Factor Power Supply Replacement, Remove the Power Supply from the Case: paso 3, imagen 1 de 2 Dell Optiplex 745 Small Form Factor Power Supply Replacement, Remove the Power Supply from the Case: paso 3, imagen 2 de 2
    • Identify the power supply.
    • Remove the two 9.5 mm Phillips screws on the outside of the case.
  4. Dell Optiplex 745 Small Form Factor Power Supply Replacement, Disconnect the power supply cables: paso 4, imagen 1 de 2 Dell Optiplex 745 Small Form Factor Power Supply Replacement, Disconnect the power supply cables: paso 4, imagen 2 de 2
    • Grab the plastic casing and pull out the bundle of cables from the side of the power supply unit.
  5. Dell Optiplex 745 Small Form Factor Power Supply Replacement, Remove the power supply: paso 5, imagen 1 de 1
    • Push the power supply from the back and lift from the front.
    • Lift the power supply out of the case.
Conclusión
16 personas más completaron esta guía.
Samantha Hsu
Miembro Desde 09/29/14
416 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 13-10, Forte Fall 2014 Miembro de Cal Poly, Team 13-10, Forte Fall 2014
CPSU-FORTE-F14S13G10
Miembros de 6
12 Guías creadas
1Guía Comentario
good, but that's not the SFF model.
99mmarriott99 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 27
Todo El Tiempo: 6,854
