Saltar al contenido principal
Dell Optiplex 745 Small Form Factor Motherboard Replacement
Qué necesitas
  1. Dell Optiplex 745 Small Form Factor Motherboard Replacement, Opening the case: paso 1, imagen 1 de 2 Dell Optiplex 745 Small Form Factor Motherboard Replacement, Opening the case: paso 1, imagen 2 de 2
    • Pull the tab and the lid will pop up.
  2. Dell Optiplex 745 Small Form Factor Motherboard Replacement: paso 2, imagen 1 de 2 Dell Optiplex 745 Small Form Factor Motherboard Replacement: paso 2, imagen 2 de 2
    • Grab the lid and pull it up and off.
  3. Dell Optiplex 745 Small Form Factor Motherboard Replacement, Motherboard: paso 3, imagen 1 de 3 Dell Optiplex 745 Small Form Factor Motherboard Replacement, Motherboard: paso 3, imagen 2 de 3 Dell Optiplex 745 Small Form Factor Motherboard Replacement, Motherboard: paso 3, imagen 3 de 3
    • Disconnect all of the cords that are connected to the motherboard.
    • Press in the lever on the side of the male end, and then pull out.
    • Pull cord straight out.
    • Disconnect the front plate (USB and audio output) from the motherboard.
    • Some of the cords in the pictures are missing due to the condition of our device when creating this guide.
  4. Dell Optiplex 745 Small Form Factor Motherboard Replacement: paso 4, imagen 1 de 3 Dell Optiplex 745 Small Form Factor Motherboard Replacement: paso 4, imagen 2 de 3 Dell Optiplex 745 Small Form Factor Motherboard Replacement: paso 4, imagen 3 de 3
    • Remove the graphics card.
    • Lift the blue latch on the fat end of the graphics card.
    • Pull the blue lever on the skinny end of the graphics card toward the power supply.
    • Pull out one end of the card at a time.
  5. Dell Optiplex 745 Small Form Factor Motherboard Replacement: paso 5, imagen 1 de 3 Dell Optiplex 745 Small Form Factor Motherboard Replacement: paso 5, imagen 2 de 3 Dell Optiplex 745 Small Form Factor Motherboard Replacement: paso 5, imagen 3 de 3
    • Remove the heat sink.
    • Unscrew the (2) two screws using a Phillips #2 screwdriver and lift out the heat sink.
  6. Dell Optiplex 745 Small Form Factor Motherboard Replacement: paso 6, imagen 1 de 3 Dell Optiplex 745 Small Form Factor Motherboard Replacement: paso 6, imagen 2 de 3 Dell Optiplex 745 Small Form Factor Motherboard Replacement: paso 6, imagen 3 de 3
    • Remove the (5) five 6mm Phillips #2 screws from the motherboard.
    • Remove the (2) two 17mm Phillips #2 screws from the mount for the heat sink.
  7. Dell Optiplex 745 Small Form Factor Motherboard Replacement: paso 7, imagen 1 de 3 Dell Optiplex 745 Small Form Factor Motherboard Replacement: paso 7, imagen 2 de 3 Dell Optiplex 745 Small Form Factor Motherboard Replacement: paso 7, imagen 3 de 3
    • Remove the back plate by lifting straight out by the blue latch that secures the graphics card.
    • Pull the end of the motherboard closest to the back of the computer away from the static back plate.
    • Lift this end away and out of the case.
Conclusión
7 personas más completaron esta guía.
Alexander Rosner
Miembro Desde 10/03/17
291 Reputación
1 Guía escrita
Equipo
USF Tampa, Team S5-G5, Walkup Fall 2017 Miembro de USF Tampa, Team S5-G5, Walkup Fall 2017
USFT-WALKUP-F17S5G5
4 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 15
Todo El Tiempo: 1,952
