Saltar al contenido principal
Dell Optiplex 745 Small Form Factor Audio Components Replacement
Qué necesitas
  1. Dell Optiplex 745 Small Form Factor Audio Components Replacement, Opening the case: paso 1, imagen 1 de 2 Dell Optiplex 745 Small Form Factor Audio Components Replacement, Opening the case: paso 1, imagen 2 de 2
    • Pull the tab and the lid will pop up.
  2. Dell Optiplex 745 Small Form Factor Audio Components Replacement: paso 2, imagen 1 de 2 Dell Optiplex 745 Small Form Factor Audio Components Replacement: paso 2, imagen 2 de 2
    • Grab the lid and pull it up and off.
  3. Dell Optiplex 745 Small Form Factor Audio Components Replacement, Front Audio Panel: paso 3, imagen 1 de 1
    • Disconnect the cable attached to the audio panel by gently pulling the head of the cable away from the port.
    • When creating this guide a cable was absent, in the picture you will find where that cable would be connected.
  4. Dell Optiplex 745 Small Form Factor Audio Components Replacement: paso 4, imagen 1 de 1
    • Using a Phillips #2 screw driver, unscrew the 9.5 mm screw that holds the audio panel in place.
  5. Dell Optiplex 745 Small Form Factor Audio Components Replacement: paso 5, imagen 1 de 2 Dell Optiplex 745 Small Form Factor Audio Components Replacement: paso 5, imagen 2 de 2
    • Carefully grasp the audio panel from the sides, pull it back and out of it's slot.
Conclusión
Una persona más ha completado esta guía.
Jeremy Nicholas
Miembro Desde 10/09/17
228 Reputación
2 Guías creadas
Equipo
USF Tampa, Team S5-G5, Walkup Fall 2017 Miembro de USF Tampa, Team S5-G5, Walkup Fall 2017
USFT-WALKUP-F17S5G5
4 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 14
Todo El Tiempo: 1,141
