Saltar al contenido principal
Dell OptiPlex GX260 Optical Drive Replacement
Qué necesitas
  1. Dell OptiPlex GX260 Optical Drive Replacement, Case: paso 1, imagen 1 de 2 Dell OptiPlex GX260 Optical Drive Replacement, Case: paso 1, imagen 2 de 2
    • Lay the Dell Optiplex GX260 down on a clean flat surface with the rear towards you.
    • Push the oval shaped buttons located on the top and bottom of the PC simultaneously and lift the case straight up.
    • Note: Some force may be required to push in the oval buttons open the PC case.
  2. Dell OptiPlex GX260 Optical Drive Replacement, Optical Drive: paso 2, imagen 1 de 3 Dell OptiPlex GX260 Optical Drive Replacement, Optical Drive: paso 2, imagen 2 de 3 Dell OptiPlex GX260 Optical Drive Replacement, Optical Drive: paso 2, imagen 3 de 3
    • Identify the optical drive in the case.
    • Remove the analog audio cable from the optical drive.
    • Remove the IDE cable form the optical drive by pulling straight up on the orange plastic tab..
    • Remove the power cable from the optical drive.
  3. Dell OptiPlex GX260 Optical Drive Replacement: paso 3, imagen 1 de 1
    • Push the two green tabs toward each other to release the optical drive and lift it out.
Conclusión
5 personas más completaron esta guía.
Kevin Schapansky
Miembro Desde 10/05/10
1,457 Reputación
9 Guías creadas
Equipo
Cal Poly, Team 4-48, Amido Fall 2010 Miembro de Cal Poly, Team 4-48, Amido Fall 2010
CPSU-AMIDO-F10S4G48
4 Miembros
27 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 5
Todo El Tiempo: 8,839
