Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
  1. Lay the Dell Optiplex GX260 down on a clean flat surface with the rear towards you. Push the  oval shaped buttons located on the top and bottom of the PC simultaneously and lift the case straight up.
    • Lay the Dell Optiplex GX260 down on a clean flat surface with the rear towards you.
    • Push the oval shaped buttons located on the top and bottom of the PC simultaneously and lift the case straight up.
    • Note: Some force may be required to push in the oval buttons open the PC case.
Conclusión
To close the case, simply press it closed until you hear the tabs click into place.
16 personas más completaron esta guía.
Kevin Schapansky
Miembro Desde 05/10/10
1,418 Reputación
9 Guías creadas
Equipo
Cal Poly, Team 4-48, Amido Fall 2010 Miembro de Cal Poly, Team 4-48, Amido Fall 2010
CPSU-AMIDO-F10S4G48
4 Miembros
27 Guías creadas
Thanks, couldn’t for the life of me figure out how to open the silly thing. :)
technojunkie_1999 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 53
Todo El Tiempo: 16,953
