Saltar al contenido principal
Dell OptiPlex FX170 RAM Replacement
Qué necesitas
  1. Dell OptiPlex FX170 RAM  Replacement, Case: paso 1, imagen 1 de 1
    • With the base stand facing upwards, unscrew the 6mm Phillips #2 screw.
    • Pull the base stand straight up from the device.
  2. Dell OptiPlex FX170 RAM  Replacement: paso 2, imagen 1 de 2 Dell OptiPlex FX170 RAM  Replacement: paso 2, imagen 2 de 2
    • Unscrew and remove the eight 4mm Phillips #0 screws (four on top, four on bottom) from the top and bottom of the device.
  3. Dell OptiPlex FX170 RAM  Replacement: paso 3, imagen 1 de 3 Dell OptiPlex FX170 RAM  Replacement: paso 3, imagen 2 de 3 Dell OptiPlex FX170 RAM  Replacement: paso 3, imagen 3 de 3
    • Run the flat side of the spudger along the entire line of the case starting from the back where the power plug and a small screw are located.
    • Use care to not apply excessive force that could damage retaining clips while running the spudger along the case.
  4. Dell OptiPlex FX170 RAM  Replacement: paso 4, imagen 1 de 2 Dell OptiPlex FX170 RAM  Replacement: paso 4, imagen 2 de 2
    • Once the clips have been released, gently disengage the cover from the rest of case by pulling in opposite directions.
  5. Dell OptiPlex FX170 RAM  Replacement, RAM: paso 5, imagen 1 de 2 Dell OptiPlex FX170 RAM  Replacement, RAM: paso 5, imagen 2 de 2
    • Using fingers, push the clips on either side of the RAM. The RAM will pop up at a 45 degree angle when both clips are disengaged.
  6. Dell OptiPlex FX170 RAM  Replacement: paso 6, imagen 1 de 1
    • Lift and pull out the RAM.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 14
Todo El Tiempo: 1,425
