Introducción
We are going to guide you through the steps to remove the current speaker and replace it with a new speaker.
Qué necesitas
With the base stand facing upwards, unscrew the 6mm Phillips #2 screw.
Pull the base stand straight up from the device.
Using fingers, push the clips on either side of the RAM. The RAM will pop up at a 45 degree angle when both clips are disengaged.
Using the spudger, gently push on the underside of the memory board to loosen it. Gently grasp each side and pull up to release the memory board.
Remove the two 4mm Phillips #00 screws that are along the back of the case.
Gently grasp the motherboard by the heat sink (the black finned piece). Lift the motherboard at an angle such that the ports along the back side come up first.
Continue lifting the motherboard, then slowly tilt the piece off to the right to break the Mylar tape over the front USB ports.
Remove the 5mm Philips #0 screw securing the speaker mounting bracket to the case.
Una persona más ha completado esta guía.
