Saltar al contenido principal
Dell Latitude X300 Screen Replacement
Qué necesitas
  1. Dell Latitude X300 Screen Replacement, Screen: paso 1, imagen 1 de 1
    • Make sure the Dell Latitude X300 power is off.
    • Remove the battery located on the bottom of the device by pushing in both clips.
  2. Dell Latitude X300 Screen Replacement: paso 2, imagen 1 de 2 Dell Latitude X300 Screen Replacement: paso 2, imagen 2 de 2
    • Remove rubber caps on each corner of the front screen with a pinch.
    • Remove the 4 mm screws located on the front screen of the laptop.
  3. Dell Latitude X300 Screen Replacement: paso 3, imagen 1 de 1
    • Carefully, remove the screen casing using either your hands or a proper tool.
    • The casing is very flimsy, so extreme care is required.
  4. Dell Latitude X300 Screen Replacement: paso 4, imagen 1 de 1
    • Remove the 4 mm screws on the bottom left and bottom right corner of the screen.
  5. Dell Latitude X300 Screen Replacement: paso 5, imagen 1 de 2 Dell Latitude X300 Screen Replacement: paso 5, imagen 2 de 2
    • Carefully lift the screen and place it on it's face.
    • Disconnect the wiring attached to the screen.
    • It is important not to damage this wire.
Conclusión
3 personas más completaron esta guía.
Jacob
Miembro Desde 03/12/14
9 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 730
