Saltar al contenido principal
Dell Latitude X300 RAM Replacement
Qué necesitas
  1. Dell Latitude X300 RAM Replacement, RAM: paso 1, imagen 1 de 2 Dell Latitude X300 RAM Replacement, RAM: paso 1, imagen 2 de 2
    • Turn the laptop over so that the bottom is facing up.
    • Remove the two #0 3 mm screws holding the cover plate.
  2. Dell Latitude X300 RAM Replacement: paso 2, imagen 1 de 1
    • Push both metal retaining clips outward at the same time using your hands carefully.
    • If done correctly the memory should pop up at a 45 degree angle.
  3. Dell Latitude X300 RAM Replacement: paso 3, imagen 1 de 1
    • Gently pull the memory out of the retainer at the same 45 degree angle.
  4. Dell Latitude X300 RAM Replacement: paso 4, imagen 1 de 1
    • Insert the new memory at 45 degree angle.
  5. Dell Latitude X300 RAM Replacement: paso 5, imagen 1 de 1
    • Ensure the memory is in all the way before pressing the memory downward until both metal retainer clips are snapped into place.
Conclusión
To reassemble your device, reinstall cover plate with two #0 screws.
Thomas Wong
Miembro Desde 01/20/12
23 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 11-20, Maness Winter 2012 Miembro de Cal Poly, Team 11-20, Maness Winter 2012
CPSU-MANESS-W12S11G20
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 2,235
