Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y herramientas
Partes
  1. Turn the laptop over so that the bottom is facing up. Remove the two #0 3 mm screws holding the cover plate.
    • Turn the laptop over so that the bottom is facing up.
    • Remove the two #0 3 mm screws holding the cover plate.
  2. Push both metal retaining clips outward at the same time using your hands carefully.
    • Push both metal retaining clips outward at the same time using your hands carefully.
    • If done correctly the memory should pop up at a 45 degree angle.
  3. Kits para Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Gently pull the memory out of the retainer at the same 45 degree angle.
    • Gently pull the memory out of the retainer at the same 45 degree angle.
  5. Insert the new memory at 45 degree angle.
    • Insert the new memory at 45 degree angle.
  6. Ensure the memory is in all the way before pressing the memory downward until both metal retainer clips are snapped into place.
    • Ensure the memory is in all the way before pressing the memory downward until both metal retainer clips are snapped into place.
Conclusión
To reassemble your device, reinstall cover plate with two #0 screws.
Thomas Wong
Miembro Desde 20/01/12
23 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 11-20, Maness Winter 2012 Miembro de Cal Poly, Team 11-20, Maness Winter 2012
CPSU-MANESS-W12S11G20
4 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 2,041
