Saltar al contenido principal
Fix Your Stuff
Right to Repair
Parts & Tools
Partes
No se especificaron partes.
  1. Remove the four 4-mm screws on the bottom of the laptop using a #0 screw driver.
    • Remove the four 4-mm screws on the bottom of the laptop using a #0 screw driver.
  2. Carefully turn the laptop over and open the screen all the way. Locate the slot to remove the keyboard in the lower left hand corner.
    • Carefully turn the laptop over and open the screen all the way.
    • Locate the slot to remove the keyboard in the lower left hand corner.
    • Using a spudger as a lever, insert it into the slot and gently pry up.
  3. After the keyboard pops up, pull it away from the screen just enough to release the tabs.
    • After the keyboard pops up, pull it away from the screen just enough to release the tabs.
    • Don’t pull the keyboard out forcefully as there is still a ribbon attached to the laptop.
  4. Unlock the ZIF connector on the computer by pushing the two outside tabs toward the screen.
    • Unlock the ZIF connector on the computer by pushing the two outside tabs toward the screen.
  5. Remove the flexible ribbon from ZIF connector.
    • Remove the flexible ribbon from ZIF connector.
    • Do not pull on the ribbon to remove it from the ZIF connector.
Conclusión
Jacob Egorov
Miembro Desde 20/01/12
1 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 11-20, Maness Winter 2012 Miembro de Cal Poly, Team 11-20, Maness Winter 2012
CPSU-MANESS-W12S11G20
4 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 1,131
