Saltar al contenido principal
Dell Latitude X300 Keyboard Replacement
Qué necesitas
  1. Dell Latitude X300 Keyboard Replacement, Keyboard: paso 1, imagen 1 de 1
    • Remove the four 4 mm Phillips #0 screws from the bottom of the laptop.
  2. Dell Latitude X300 Keyboard Replacement: paso 2, imagen 1 de 2 Dell Latitude X300 Keyboard Replacement: paso 2, imagen 2 de 2
    • Carefully turn the laptop over and open the screen all the way.
    • Locate the slot to remove the keyboard in the lower left hand corner.
    • Using a spudger as a lever, insert it into the slot and gently pry up.
  3. Dell Latitude X300 Keyboard Replacement: paso 3, imagen 1 de 1
    • After the keyboard pops up, pull it away from the screen just enough to release the tabs.
    • Don’t pull the keyboard out forcefully as there is still a ribbon attached to the laptop.
  4. Dell Latitude X300 Keyboard Replacement: paso 4, imagen 1 de 1
    • Unlock the ZIF connector on the computer by pushing the two outside tabs toward the screen.
  5. Dell Latitude X300 Keyboard Replacement: paso 5, imagen 1 de 1
    • Remove the flexible ribbon from the ZIF connector.
    • Do not pull on the ribbon to remove it from the ZIF connector.
Conclusión
Jacob Egorov
Miembro Desde 01/20/12
1 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 11-20, Maness Winter 2012 Miembro de Cal Poly, Team 11-20, Maness Winter 2012
CPSU-MANESS-W12S11G20
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 1,255
