Saltar al contenido principal
Dell Latitude ST Battery Replacement
Qué necesitas
  1. Dell Latitude ST Battery Replacement, Battery: paso 1, imagen 1 de 3 Dell Latitude ST Battery Replacement, Battery: paso 1, imagen 2 de 3 Dell Latitude ST Battery Replacement, Battery: paso 1, imagen 3 de 3
    • Locate the back panel tab.
    • Press down on the tab to remove the panel.
  2. Dell Latitude ST Battery Replacement: paso 2, imagen 1 de 3 Dell Latitude ST Battery Replacement: paso 2, imagen 2 de 3 Dell Latitude ST Battery Replacement: paso 2, imagen 3 de 3
    • Using a Phillips #0 screwdriver, remove the four 6mm screws attaching the inside panel to the device.
  3. Dell Latitude ST Battery Replacement: paso 3, imagen 1 de 3 Dell Latitude ST Battery Replacement: paso 3, imagen 2 de 3 Dell Latitude ST Battery Replacement: paso 3, imagen 3 de 3
    • Use the blue plastic opening tool to push in the tab located on the backside of the device.
    • Slide the tool around the edges of the device to unsnap the tabs and pry the frame off.
  4. Dell Latitude ST Battery Replacement: paso 4, imagen 1 de 3 Dell Latitude ST Battery Replacement: paso 4, imagen 2 de 3 Dell Latitude ST Battery Replacement: paso 4, imagen 3 de 3
    • Remove the three 6mm Phillips #0 screws attaching the battery.
  5. Dell Latitude ST Battery Replacement: paso 5, imagen 1 de 3 Dell Latitude ST Battery Replacement: paso 5, imagen 2 de 3 Dell Latitude ST Battery Replacement: paso 5, imagen 3 de 3
    • Using your hands or a plastic opening tool, unplug the white battery cable.
    • Push forward on the top part of the cable to disconnect it from the device.
  6. Dell Latitude ST Battery Replacement: paso 6, imagen 1 de 3 Dell Latitude ST Battery Replacement: paso 6, imagen 2 de 3 Dell Latitude ST Battery Replacement: paso 6, imagen 3 de 3
    • Pull up on the black tab located at the top of the battery to remove the battery from the device.
Conclusión
Una persona más ha completado esta guía.
2 comentarios
Where can I get the battery for it
Brandon Allen - Contestar
Where do I find a new battery for it at
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 19
Todo El Tiempo: 966
