Saltar al contenido principal
Dell Latitude E7470 Network Card Replacement
Qué necesitas
  1. Dell Latitude E7470 Network Card Replacement, Back Cover: paso 1, imagen 1 de 1
    • Remove the eight 4 mm screws on the back cover using a Phillips #0 screwdriver.
  2. Dell Latitude E7470 Network Card Replacement, Battery: paso 2, imagen 1 de 1
    • Use the pull tab on the battery connector to lift the connector straight up off its socket on the motherboard, disconnecting it.
  3. Dell Latitude E7470 Network Card Replacement: paso 3, imagen 1 de 2 Dell Latitude E7470 Network Card Replacement: paso 3, imagen 2 de 2
    • Remove the single 4 mm Phillips screw securing the bottom left corner of the battery.
    • If you are removing an extended capacity battery, remove the Phillips screw securing the bottom right corner of the battery.
  4. Dell Latitude E7470 Network Card Replacement: paso 4, imagen 1 de 1
    • Remove the battery from the laptop.
  5. Dell Latitude E7470 Network Card Replacement, Network Card: paso 5, imagen 1 de 2 Dell Latitude E7470 Network Card Replacement, Network Card: paso 5, imagen 2 de 2
    Herramienta utilizada en este paso:
    Halberd Spudger
    $2.99
    • Use a halberd spudger and your fingers to detach two wires from the Wi-Fi card.
  6. Dell Latitude E7470 Network Card Replacement: paso 6, imagen 1 de 1
    • Remove the single screw from the Wi-Fi card using a Phillips #0 screwdriver.
  7. Dell Latitude E7470 Network Card Replacement: paso 7, imagen 1 de 1
    • Use an iFixit opening tool and your fingers to pull the Wi-Fi card out of its socket.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 15
Todo El Tiempo: 870
