Saltar al contenido principal
Dell Latitude E7470 Fan and Heatsink Replacement
Qué necesitas
  1. Aviso: el paso 1 proviene de una guía que está marcada como "En progreso".
    Dell Latitude E7470 Fan and Heatsink Replacement, Back Cover: paso 1, imagen 1 de 1
    • Remove the eight 4 mm screws on the back cover using a Phillips #0 screwdriver.
  2. Dell Latitude E7470 Fan and Heatsink Replacement, Battery: paso 2, imagen 1 de 1
    • Use the pull tab on the battery connector to lift the connector straight up off its socket on the motherboard, disconnecting it.
  3. Dell Latitude E7470 Fan and Heatsink Replacement: paso 3, imagen 1 de 2 Dell Latitude E7470 Fan and Heatsink Replacement: paso 3, imagen 2 de 2
    • Remove the single 4 mm Phillips screw securing the bottom left corner of the battery.
    • If you are removing an extended capacity battery, remove the Phillips screw securing the bottom right corner of the battery.
  4. Dell Latitude E7470 Fan and Heatsink Replacement: paso 4, imagen 1 de 1
    • Remove the battery from the laptop.
  5. Dell Latitude E7470 Fan and Heatsink Replacement, Fan and Heatsink: paso 5, imagen 1 de 2 Dell Latitude E7470 Fan and Heatsink Replacement, Fan and Heatsink: paso 5, imagen 2 de 2
    • After opening the backcase of the computer, remove the screws using the Phillips #0 screwdriver.
    • Unplug and remove the wire from the socket.
  6. Dell Latitude E7470 Fan and Heatsink Replacement: paso 6, imagen 1 de 1
    • Remove the fan and heatsink from the laptop.
    • Make sure to wipe off the existing thermal paste from the CPU and heatsink with an alcohol-soaked pad and apply a new layer.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 13
Ultimos 30 días: 40
Todo El Tiempo: 2,563
