Saltar al contenido principal
Dell Latitude E7440 Trackpad Replacement
Qué necesitas
  1. Dell Latitude E7440 Trackpad Replacement, Trackpad: paso 1, imagen 1 de 2 Dell Latitude E7440 Trackpad Replacement, Trackpad: paso 1, imagen 2 de 2
    • Slide the latch and remove the battery.
  2. Dell Latitude E7440 Trackpad Replacement: paso 2, imagen 1 de 3 Dell Latitude E7440 Trackpad Replacement: paso 2, imagen 2 de 3 Dell Latitude E7440 Trackpad Replacement: paso 2, imagen 3 de 3
    • Remove two 3mm screws using the Phillips #0 screwdriver.
    • Slide access door down and remove it by slightly jerking it. Make sure no part of the door is sticking to the components.
  3. Dell Latitude E7440 Trackpad Replacement: paso 3, imagen 1 de 3 Dell Latitude E7440 Trackpad Replacement: paso 3, imagen 2 de 3 Dell Latitude E7440 Trackpad Replacement: paso 3, imagen 3 de 3
    • Remove two 5mm screws using the Phillips #0 screwdriver.
    • Unplug highlighted cable. Be careful not to snap it in half.
  4. Dell Latitude E7440 Trackpad Replacement: paso 4, imagen 1 de 1
    • Remove the fan from the device.
  5. Dell Latitude E7440 Trackpad Replacement: paso 5, imagen 1 de 3 Dell Latitude E7440 Trackpad Replacement: paso 5, imagen 2 de 3 Dell Latitude E7440 Trackpad Replacement: paso 5, imagen 3 de 3
    • Remove cables on the bottom.
  6. Dell Latitude E7440 Trackpad Replacement: paso 6, imagen 1 de 3 Dell Latitude E7440 Trackpad Replacement: paso 6, imagen 2 de 3 Dell Latitude E7440 Trackpad Replacement: paso 6, imagen 3 de 3
    • Remove the following screws using the Phillips #0 screwdriver.
    • Five 5mm screws.
    • Seven 3mm screws.
    • One 8mm screw.
  7. Dell Latitude E7440 Trackpad Replacement: paso 7, imagen 1 de 1
    • Remove the keyboard bezel. This might take some effort. Use some force in one direction only.
  8. Dell Latitude E7440 Trackpad Replacement: paso 8, imagen 1 de 2 Dell Latitude E7440 Trackpad Replacement: paso 8, imagen 2 de 2
    • Remove the two 2.5mm mouse button screws using the Phillips #0 screwdriver.
    • Remove the mouse button.
  9. Dell Latitude E7440 Trackpad Replacement: paso 9, imagen 1 de 3 Dell Latitude E7440 Trackpad Replacement: paso 9, imagen 2 de 3 Dell Latitude E7440 Trackpad Replacement: paso 9, imagen 3 de 3
    • Remove three 3mm screws using the Phillips #0 screwdriver.
    • Remove the keyboard by pulling it in one direction.
  10. Dell Latitude E7440 Trackpad Replacement: paso 10, imagen 1 de 3 Dell Latitude E7440 Trackpad Replacement: paso 10, imagen 2 de 3 Dell Latitude E7440 Trackpad Replacement: paso 10, imagen 3 de 3
    • Disconnect the cables from the device.
    • Remove a single 5mm screw using the Phillips #0 screwdriver.
    • Remove the trackpad panel.
Conclusión
2 personas más completaron esta guía.
Equipo
IUPUI, Team S1-G1, Stella Fall 2019 Miembro de IUPUI, Team S1-G1, Stella Fall 2019
IUPUI-STELLA-F19S1G1
4 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 29
Todo El Tiempo: 2,850
