Saltar al contenido principal
Dell Latitude E7440 RAM Replacement
Qué necesitas
  1. Dell Latitude E7440 RAM Replacement, Prepare the laptop: paso 1, imagen 1 de 1
    • Power off your laptop before starting.
    • Flip the device over so that the vents on the bottom are facing away from you.
  2. Dell Latitude E7440 RAM Replacement, Release the battery: paso 2, imagen 1 de 3 Dell Latitude E7440 RAM Replacement, Release the battery: paso 2, imagen 2 de 3 Dell Latitude E7440 RAM Replacement, Release the battery: paso 2, imagen 3 de 3
    • Place your finger on the latch located in the center of the laptop.
    • Slide the latch to the right, applying enough force to reveal a red indicator.
    • You will hear a soft click when the latch has been disengaged.
  3. Dell Latitude E7440 RAM Replacement, Remove the battery: paso 3, imagen 1 de 1
    • Lift the battery by the top, away from the laptop body.
  4. Dell Latitude E7440 RAM Replacement, RAM: paso 4, imagen 1 de 2 Dell Latitude E7440 RAM Replacement, RAM: paso 4, imagen 2 de 2
    • Remove two M2 x 3mm Phillips #0 screws from the base cover.
  5. Dell Latitude E7440 RAM Replacement: paso 5, imagen 1 de 2 Dell Latitude E7440 RAM Replacement: paso 5, imagen 2 de 2
    • Slide the base cover down slightly and remove it.
  6. Dell Latitude E7440 RAM Replacement: paso 6, imagen 1 de 3 Dell Latitude E7440 RAM Replacement: paso 6, imagen 2 de 3 Dell Latitude E7440 RAM Replacement: paso 6, imagen 3 de 3
    • For each RAM module, pull apart both the clips and remove the memory.
    • iFixit’s device came without RAM installed. Your device will have a module between each set of clips.
Conclusión
6 personas más completaron esta guía.
Akash Kedia
Miembro Desde 01/24/19
1,445 Reputación
5 Guías creadas
Equipo
Cal Poly, Team S2-G5, White Winter 2019 Miembro de Cal Poly, Team S2-G5, White Winter 2019
CPSU-WHITE-W19S2G5
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 8
Ultimos 7 días: 23
Ultimos 30 días: 48
Todo El Tiempo: 2,882
