Saltar al contenido principal
Dell Latitude E7440 Battery Replacement
Qué necesitas
  1. Dell Latitude E7440 Battery Replacement, Prepare the laptop: paso 1, imagen 1 de 1
    • Power off your laptop before starting.
    • Flip the device over so that the vents on the bottom are facing away from you.
  2. Dell Latitude E7440 Battery Replacement, Release the battery: paso 2, imagen 1 de 3 Dell Latitude E7440 Battery Replacement, Release the battery: paso 2, imagen 2 de 3 Dell Latitude E7440 Battery Replacement, Release the battery: paso 2, imagen 3 de 3
    • Place your finger on the latch located in the center of the laptop.
    • Slide the latch to the right, applying enough force to reveal a red indicator.
    • You will hear a soft click when the latch has been disengaged.
  3. Dell Latitude E7440 Battery Replacement, Remove the battery: paso 3, imagen 1 de 1
    • Lift the battery by the top, away from the laptop body.
Conclusión
8 personas más completaron esta guía.
Akash Kedia
Miembro Desde 01/24/19
1,397 Reputación
5 Guías creadas
Equipo
Cal Poly, Team S2-G5, White Winter 2019 Miembro de Cal Poly, Team S2-G5, White Winter 2019
CPSU-WHITE-W19S2G5
4 Miembros
5 Guías creadas
2 comentarios
I wan to reconstruct this battery but I don’t find the model of the cells to be able to buy them…
Anwar Ben Tanfous - Contestar
Any recommended site to buy original battery?
Razin Ahmed - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 17
Ultimos 30 días: 66
Todo El Tiempo: 5,307
