Saltar al contenido principal
Dell Latitude E7270 Motherboard Removal
Qué necesitas
  1. Dell Latitude E7270 Motherboard Removal, Back Panel: paso 1, imagen 1 de 1
    • Place the device top down in front of you so that the vents are visible and are furthest from the user.
    • Please be sure that the device is powered off and unplugged before removing parts or deconstructing anything.
  2. Dell Latitude E7270 Motherboard Removal: paso 2, imagen 1 de 1
    • Remove all eight M2.5 X 8MM screws with a Phillips #00 screwdriver.
  3. Dell Latitude E7270 Motherboard Removal: paso 3, imagen 1 de 1
    • Lift and remove the panel.
  4. Dell Latitude E7270 Motherboard Removal, Battery: paso 4, imagen 1 de 1
    • Remove the three M2.5 X 5MM screws, located above the battery, with a Phillips #00 screwdriver.
  5. Dell Latitude E7270 Motherboard Removal: paso 5, imagen 1 de 2 Dell Latitude E7270 Motherboard Removal: paso 5, imagen 2 de 2
    • Disconnect the battery wire by using your fingers to pull diagonally left on the tab.
  6. Dell Latitude E7270 Motherboard Removal: paso 6, imagen 1 de 1
    • Remove the battery completely by grabbing an edge and pulling up on the battery.
  7. Dell Latitude E7270 Motherboard Removal, Cooling Fan: paso 7, imagen 1 de 3 Dell Latitude E7270 Motherboard Removal, Cooling Fan: paso 7, imagen 2 de 3 Dell Latitude E7270 Motherboard Removal, Cooling Fan: paso 7, imagen 3 de 3
    • Remove the 4 pin fan power connector from the motherboard by using your finger and pulling up.
    • Remove the four M2.5 X 5MM screws that hold on the rectangular bracket located towards the center of the motherboard using a Phillips #00 screwdriver.
    • Remove the three M2.5 X 5MM screws that hold down the circular fan bracket using a Phillips #00 screwdriver.
  8. Dell Latitude E7270 Motherboard Removal: paso 8, imagen 1 de 1
    • Lift and remove fan by pulling gently straight up using your fingers
  9. Dell Latitude E7270 Motherboard Removal: paso 9, imagen 1 de 1
    • Before replacing fan, make sure to place a small amount of thermal paste to ensure proper heat dissipation and long term life.
  10. Dell Latitude E7270 Motherboard Removal, Motherboard Replacement: paso 10, imagen 1 de 3 Dell Latitude E7270 Motherboard Removal, Motherboard Replacement: paso 10, imagen 2 de 3 Dell Latitude E7270 Motherboard Removal, Motherboard Replacement: paso 10, imagen 3 de 3
    • Remove the 10 wire connections by using your fingers to separate the connections.
    • Remove the thirteen M2.5 X 5MM screws that fasten the motherboard using a Phillips #00 screwdriver.
    • Remove the two M2.5 X 8MM external screws that fasten the motherboard from outside using a Phillips #00 screwdriver.
  11. Dell Latitude E7270 Motherboard Removal: paso 11, imagen 1 de 1
    • Lift and remove the motherboard by grabbing the outside edges and pulling straight up.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 21
Ultimos 30 días: 41
Todo El Tiempo: 3,082
