Saltar al contenido principal
Dell Latitude E7250 SSD Replacement
Qué necesitas
  1. Dell Latitude E7250 SSD Replacement, Battery: paso 1, imagen 1 de 2 Dell Latitude E7250 SSD Replacement, Battery: paso 1, imagen 2 de 2
    • Slide the battery release all the way to the right.
    • Once the battery release is pulled all the way, the battery will lift itself slightly from the casing.
    • Remove the battery.
  2. Dell Latitude E7250 SSD Replacement, SSD: paso 2, imagen 1 de 3 Dell Latitude E7250 SSD Replacement, SSD: paso 2, imagen 2 de 3 Dell Latitude E7250 SSD Replacement, SSD: paso 2, imagen 3 de 3
    • With the battery removed two screws will be visible. These will need to be removed.
    • Placing your hands on either side of the panel, push down and pull back to slide the plate back and off.
  3. Dell Latitude E7250 SSD Replacement: paso 3, imagen 1 de 3 Dell Latitude E7250 SSD Replacement: paso 3, imagen 2 de 3 Dell Latitude E7250 SSD Replacement: paso 3, imagen 3 de 3
    • Locate your SSD, it is on the right side and held in with a small screw.
    • Unscrew the SSD carefully. Once done, the SSD will "pop" upwards at an angle making removal easy.
    • Gently grasp the SSD on either side with your thumb and forefinger and pull away from the computer.
Conclusión
7 personas más completaron esta guía.
Un comentario
Thanks a lot for this !
viperx007 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 36
Ultimos 30 días: 144
Todo El Tiempo: 10,831
