Saltar al contenido principal
Dell Latitude E7250 RAM Replacement
Qué necesitas
  1. Dell Latitude E7250 RAM Replacement, Battery: paso 1, imagen 1 de 2 Dell Latitude E7250 RAM Replacement, Battery: paso 1, imagen 2 de 2
    • Slide the battery release all the way to the right.
    • Once the battery release is pulled all the way, the battery will lift itself slightly from the casing.
    • Remove the battery.
  2. Dell Latitude E7250 RAM Replacement, RAM: paso 2, imagen 1 de 3 Dell Latitude E7250 RAM Replacement, RAM: paso 2, imagen 2 de 3 Dell Latitude E7250 RAM Replacement, RAM: paso 2, imagen 3 de 3
    • With the battery removed two screws will be visible. These will need to be removed.
    • Placing your hands on either side of the panel, push down and pull back to slide the plate back and off.
  3. Dell Latitude E7250 RAM Replacement: paso 3, imagen 1 de 3 Dell Latitude E7250 RAM Replacement: paso 3, imagen 2 de 3 Dell Latitude E7250 RAM Replacement: paso 3, imagen 3 de 3
    • The RAM stick will be located on the left side of the computer.
    • Located on either side of the RAM stick is a pair of metal bars. Gently pull them to the side of the ram and it will lift upwards.
    • Pull the RAM stick gently, at an angle away from the rest of the computer.
Conclusión
3 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 7
Ultimos 30 días: 51
Todo El Tiempo: 4,866
