Saltar al contenido principal
Dell Latitude E7250 CMOS Replacement
Qué necesitas
  1. Dell Latitude E7250 CMOS Replacement, removing the battery: paso 1, imagen 1 de 2 Dell Latitude E7250 CMOS Replacement, removing the battery: paso 1, imagen 2 de 2
    • Slide the release latch to unlock the battery
    • Lift the battery from the computer.
  2. Dell Latitude E7250 CMOS Replacement, Remove base cover: paso 2, imagen 1 de 2 Dell Latitude E7250 CMOS Replacement, Remove base cover: paso 2, imagen 2 de 2
    • Remove the screws that secure the base cover to the computer
    • Slide the base cover
  3. Dell Latitude E7250 CMOS Replacement, Removing the Keyboard Trim: paso 3, imagen 1 de 2 Dell Latitude E7250 CMOS Replacement, Removing the Keyboard Trim: paso 3, imagen 2 de 2
    • Using a plastic scribe, pry the edges of keyboard trim to release it from the computer
    • Lift up to remove the keyboard trim from the computer.
  4. Dell Latitude E7250 CMOS Replacement, Removing the Keyboard: paso 4, imagen 1 de 3 Dell Latitude E7250 CMOS Replacement, Removing the Keyboard: paso 4, imagen 2 de 3 Dell Latitude E7250 CMOS Replacement, Removing the Keyboard: paso 4, imagen 3 de 3
    • Lift the battery bay that secures the keyboard to the computer
    • Lift the latch that secure the keyboard cable to the computer
    • Disconnect the keyboard cable the computer
  5. Dell Latitude E7250 CMOS Replacement, Removing the SSD Card: paso 5, imagen 1 de 1
    • Remove the screws that secure the SSD card to the computer
    • Lift and remove the SSD card from the computer
  6. Dell Latitude E7250 CMOS Replacement, Removing the Palmrest: paso 6, imagen 1 de 3 Dell Latitude E7250 CMOS Replacement, Removing the Palmrest: paso 6, imagen 2 de 3 Dell Latitude E7250 CMOS Replacement, Removing the Palmrest: paso 6, imagen 3 de 3
    • Remove the screws that secure the palmrest assembly and flip the computer.
    • Perform the following steps as shown in the illustration: a. Lift the latch that secures the keyboard and touch cable to the computer [1]. b. Disconnect the keyboard and touch cable to the computer [2]. c. Remove the screws that secure the palmrest assembly to the computer [3].
    • Perform the following steps as shown in the illustration: a. Pry the edges of the palmrest assembly [1]. b. Lift the palmrest assembly from the computer [2].
  7. Dell Latitude E7250 CMOS Replacement, Removing/ Installing the Coin-Cell Battery: paso 7, imagen 1 de 1
    • Perform the following steps as shown in the illustration: a. Disconnect the coin-cell cable from the computer [1]. b. Lift the coin-cell battery from the computer [2]
    • Installing the Coin-Cell Battery 1. Place the Coin-cell battery on the computer. 2. Connect the coin-cell battery cable to the computer
Conclusión
Una persona más ha completado esta guía.
Jordon Dozier
Miembro Desde 02/10/21
1,663 Reputación
12 Guías creadas
Equipo
RampUP America, Inc. Miembro de RampUP America, Inc.
Community
43 Miembros
1,985 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 10
Todo El Tiempo: 926
