Saltar al contenido principal
Dell Latitude E6530 Battery Replacement
  1. Dell Latitude E6530 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Flip the computer over so that the bottom panel is facing you.
  2. Dell Latitude E6530 Battery Replacement: paso 2, imagen 1 de 2 Dell Latitude E6530 Battery Replacement: paso 2, imagen 2 de 2
    • Slide the switches away from each other to release the battery.
  3. Dell Latitude E6530 Battery Replacement: paso 3, imagen 1 de 2 Dell Latitude E6530 Battery Replacement: paso 3, imagen 2 de 2
    • Using your hands, gently remove the battery from the device.
Conclusión
To reassemble your device, follow these instructions in reverse order. If issues arise after replacing the battery, refer to the troubleshooting page or additional links for more help.
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 17
Todo El Tiempo: 728
