Saltar al contenido principal
Dell Latitude E6520 WLAN Adaptor Card Replacement
Qué necesitas
  1. Dell Latitude E6520 WLAN Adaptor Card Replacement, Battery: paso 1, imagen 1 de 2 Dell Latitude E6520 WLAN Adaptor Card Replacement, Battery: paso 1, imagen 2 de 2
    • With the laptop closed and the bottom side facing up, slide the two battery latches towards the sides of the laptop.
    • When the latches are unlocked, a small logo resembling an open padlock will become visible.
  2. Dell Latitude E6520 WLAN Adaptor Card Replacement: paso 2, imagen 1 de 2 Dell Latitude E6520 WLAN Adaptor Card Replacement: paso 2, imagen 2 de 2
    • Grasp the battery from the top and pull upward.
  3. Dell Latitude E6520 WLAN Adaptor Card Replacement, Bottom Cover: paso 3, imagen 1 de 2 Dell Latitude E6520 WLAN Adaptor Card Replacement, Bottom Cover: paso 3, imagen 2 de 2
    • Remove the ten 8.6 mm JIS #0 screws.
  4. Dell Latitude E6520 WLAN Adaptor Card Replacement: paso 4, imagen 1 de 1
    • Place fingers underneath cover and pull off the cover.
  5. Dell Latitude E6520 WLAN Adaptor Card Replacement, WLAN Adapter Card: paso 5, imagen 1 de 1
    • Gently pull the two wires connected to the WLAN Adapter Card.
  6. Dell Latitude E6520 WLAN Adaptor Card Replacement: paso 6, imagen 1 de 2 Dell Latitude E6520 WLAN Adaptor Card Replacement: paso 6, imagen 2 de 2
    • Remove the two electrode connectors.
    • Remove the single 3.67 mm JIS #0 screw that holds the WLAN Adapter Card to the laptop.
    • The WLAN Adapter Card will pop up once the screws are taken out.
  7. Dell Latitude E6520 WLAN Adaptor Card Replacement: paso 7, imagen 1 de 2 Dell Latitude E6520 WLAN Adaptor Card Replacement: paso 7, imagen 2 de 2
    • Pull WLAN Adapter Card to remove it from the laptop.
Conclusión
Una persona más ha completado esta guía.
Alec Weiss
Miembro Desde 11/05/18
800 Reputación
8 Guías creadas
Equipo
IUPUI, Team S2-G2, Baechle Fall 2018 Miembro de IUPUI, Team S2-G2, Baechle Fall 2018
IUPUI-BAECHLE-F18S2G2
3 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 12
Ultimos 30 días: 26
Todo El Tiempo: 930
