Introducción
The steps in this guide will require a JIS #0 screw driver to remove 6 screws with a head size of approximately 4.36mm and length of 3.63mm.
Qué necesitas
With the laptop closed and the bottom side facing up, slide the two battery latches towards the sides of the laptop.
Pry off the plastic keyboard trim. It is easiest to start at the bottom of the keyboard.
Un comentario
Hello,
Nice instructions, could someone please tell me what are the other conector/ribbions used for in this dell e6520 under the keyboard ? any help will most appreciated.
Thanks in advance
