Introducción
As a quick warning before you dive into replacing your speakers, this will be a long, hard task. By the time you will even see the speakers the laptop will be completely taken apart. Make sure to not lose your screws and ensure you have plenty of time and space before you follow this guide.
Qué necesitas
Paso 1 Keyboard
Aviso: los pasos 1-3 provienen de una guía que está marcada como "En progreso".
Open the laptop and locate the volume panel on the keyboard.
Use the spudger to get underneath the righthand side of the panel and gently pry up the side.
Paso 4 Battery
Aviso: los pasos 4-6 provienen de una guía que está marcada como "En progreso".
Position the laptop upside down with the battery facing towards you.
Locate the battery latches circled in red.
Paso 7 Fan
Aviso: los pasos 7-11 provienen de una guía que está marcada como "En progreso".
Flip over laptop and locate door panel screws.
Remove the Screws.
2 personas más completaron esta guía.
