Saltar al contenido principal
Dell Latitude E6510 RAM Replacement
Qué necesitas
  1. Dell Latitude E6510 RAM Replacement, RAM: paso 1, imagen 1 de 3 Dell Latitude E6510 RAM Replacement, RAM: paso 1, imagen 2 de 3 Dell Latitude E6510 RAM Replacement, RAM: paso 1, imagen 3 de 3
    • Orient the laptop so that the bottom is facing up towards you.
    • Place your thumbs on the grooved sections above the battery and firmly pull away from each other.
    • Slide the battery out and separate it from the laptop.
  2. Dell Latitude E6510 RAM Replacement: paso 2, imagen 1 de 3 Dell Latitude E6510 RAM Replacement: paso 2, imagen 2 de 3 Dell Latitude E6510 RAM Replacement: paso 2, imagen 3 de 3
    • Remove the 5 screws from the back panel with a type 0 Phillips head.
    • Pull the panel towards you in a slightly upwards motion.
    • Remove the panel from the laptop and set it aside.
  3. Dell Latitude E6510 RAM Replacement: paso 3, imagen 1 de 3 Dell Latitude E6510 RAM Replacement: paso 3, imagen 2 de 3 Dell Latitude E6510 RAM Replacement: paso 3, imagen 3 de 3
    • Locate the RAM sticks in the laptop.
    • Using your fingers, disconnect the prongs connected to the RAM sticks.
    • Gently remove the RAM from the port.
    • Repeat the first three steps to remove the second RAM stick.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 280
