Saltar al contenido principal
Dell Latitude E6510 RAM Replacement
Qué necesitas
  1. Dell Latitude E6510 RAM Replacement, RAM: paso 1, imagen 1 de 1
    • Use a J1 screwdriver to remove the 8mm screw on the bottom cover.
  2. Dell Latitude E6510 RAM Replacement: paso 2, imagen 1 de 1
    • Unclasp and pull the memory card up.
    • Be careful when unclasping and releasing the memory card. Clasps are fragile.
Conclusión
3 personas más completaron esta guía.
Kolin Doyle
Miembro Desde 11/06/17
500 Reputación
4 Guías creadas
Equipo
Baylor, Team S8-G4, Johnson Fall 2017 Miembro de Baylor, Team S8-G4, Johnson Fall 2017
BU-JOHNSON-F17S8G4
1 Miembro
4 Guías creadas
Un comentario
There should be four steps to this, step two should be removing the 4 hard drive screws,
step three should be removing the bottom cover, including that it slides off, as many bottom covers snap in.
I almost damaged the bottom cover trying to pry it up.
Brian Barlow - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 21
Ultimos 30 días: 24
Todo El Tiempo: 2,075
