Saltar al contenido principal
Dell Latitude E6500 Hard Drive Replacement
Qué necesitas
  1. Dell Latitude E6500 Hard Drive Replacement, removing hard drive: paso 1, imagen 1 de 1
    • Do not remove the hard drive while the computer is on or in sleep state. This might cause data loss.
    • Place the computer upside down on a clean, flat surface. Remove the bottom of the base assembly
    • Remove the bottom of the base assembly
  2. Dell Latitude E6500 Hard Drive Replacement, remove screws: paso 2, imagen 1 de 1
    • Remove the four M3 x 3-mm screws (marked with an "H") that secure the hard drive
    • Slide the hard drive out of the computer.
  3. Dell Latitude E6500 Hard Drive Replacement, remove the M3 x 3mm screw from the bezel: paso 4, imagen 1 de 1
    • Remove the M3 x 3mm screw from the bezel and take the bezel off the hard drive.
    • Attach the bezel to the hard drive using the M3 x 3mm screw.
    • Slide the hard drive into the bay until it is fully seated
Conclusión
Marvin Romero
Miembro Desde 03/18/21
3,804 Reputación
30 Guías creadas
Equipo
RampUP America, Inc. Miembro de RampUP America, Inc.
Community
43 Miembros
1,985 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 16
Todo El Tiempo: 288
