Saltar al contenido principal
Dell Latitude E6420 Fan Replacement
Qué necesitas
  1. Dell Latitude E6420 Fan Replacement, Battery: paso 1, imagen 1 de 2 Dell Latitude E6420 Fan Replacement, Battery: paso 1, imagen 2 de 2
    • Push the tabs on the left and right of the battery out towards the edge of the case.
  2. Dell Latitude E6420 Fan Replacement: paso 2, imagen 1 de 1
    • While still pushing in the tabs, using your pinky finger, lift the battery out of the laptop.
  3. Dell Latitude E6420 Fan Replacement, CD/DVD Drive: paso 3, imagen 1 de 2 Dell Latitude E6420 Fan Replacement, CD/DVD Drive: paso 3, imagen 2 de 2
    • Push the button in on the CD/DVD drive to eject the drive.
  4. Dell Latitude E6420 Fan Replacement: paso 4, imagen 1 de 2 Dell Latitude E6420 Fan Replacement: paso 4, imagen 2 de 2
    • Slide the drive out of the laptop.
    • When removing the drive, keep it flat to prevent damage to anything inside the laptop.
  5. Dell Latitude E6420 Fan Replacement, Backplate: paso 5, imagen 1 de 2 Dell Latitude E6420 Fan Replacement, Backplate: paso 5, imagen 2 de 2
    • Using the screwdriver, remove seven 4mm Phillips #1 screws from the bottom of the laptop.
    • Using the screwdriver, remove two 9mm Phillips #00 screws from the bottom of the laptop.
  6. Dell Latitude E6420 Fan Replacement: paso 6, imagen 1 de 2 Dell Latitude E6420 Fan Replacement: paso 6, imagen 2 de 2
    • Gently lift the back plate off of the laptop making sure all of the tabs on the inside perimeter of the back plate are unhooked before lifting.
    • Be careful when removing the backplate. Lifting the backplate while the tabs are still hooked in will result in broken tabs.
  7. Dell Latitude E6420 Fan Replacement, Fan: paso 7, imagen 1 de 2 Dell Latitude E6420 Fan Replacement, Fan: paso 7, imagen 2 de 2
    • Using the screwdriver, remove four 10mm Phillips #0 spring screws from the fan assembly.
  8. Dell Latitude E6420 Fan Replacement: paso 8, imagen 1 de 2 Dell Latitude E6420 Fan Replacement: paso 8, imagen 2 de 2
    • Use the plastic opening tool to unclip the connector.
  9. Dell Latitude E6420 Fan Replacement: paso 9, imagen 1 de 1
    • Lift the fan out of the laptop.
Conclusión
4 personas más completaron esta guía.
Madysen Eames
Miembro Desde 02/27/18
1,555 Reputación
7 Guías creadas
Equipo
Un comentario
very good explanatory steps. but you did not talk about the application of thermal paste for reassembly
Godwin Nwachukwu - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 17
Ultimos 30 días: 24
Todo El Tiempo: 2,317
