Saltar al contenido principal
Dell Latitude E6420 CPU Replacement
Qué necesitas
  1. Dell Latitude E6420 CPU Replacement, Rear Panel Removal: paso 1, imagen 1 de 2 Dell Latitude E6420 CPU Replacement, Rear Panel Removal: paso 1, imagen 2 de 2
    • Remove the eight screws holding down the rear panel using a Phillips #0 Screwdriver. Carefully remove base cover by hand.
  2. Dell Latitude E6420 CPU Replacement, CPU: paso 2, imagen 1 de 1
    • Remove the battery by pushing the tabs outward, then removing the battery from the device.
  3. Dell Latitude E6420 CPU Replacement: paso 3, imagen 1 de 1
    • Remove the four screws securing the heatsink using the Phillips #0 screwdriver.
    • Remove the heatsink and fan assembly.
  4. Dell Latitude E6420 CPU Replacement: paso 4, imagen 1 de 1
    • Use the flat end of a spudger to rotate the lock 180 degrees counterclockwise to unlock the CPU.
  5. Dell Latitude E6420 CPU Replacement: paso 5, imagen 1 de 2 Dell Latitude E6420 CPU Replacement: paso 5, imagen 2 de 2
    • Lift the CPU out of the motherboard assembly.
Conclusión
6 personas más completaron esta guía.
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 6
Ultimos 30 días: 43
Todo El Tiempo: 3,686
