Saltar al contenido principal
Dell Latitude E6410 Hard Drive Replacement
Qué necesitas
  1. Dell Latitude E6410 Hard Drive Replacement, 1. Remove battery: paso 1, imagen 1 de 3 Dell Latitude E6410 Hard Drive Replacement, 1. Remove battery: paso 1, imagen 2 de 3 Dell Latitude E6410 Hard Drive Replacement, 1. Remove battery: paso 1, imagen 3 de 3
    • Slide the latches on the battery and remove the battery.
  2. Dell Latitude E6410 Hard Drive Replacement, Remove Hard Drive Screws: paso 2, imagen 1 de 1
    • Use a Phillips screwdriver to remove to the screws that secure the hard drive from the hard drive caddy.
  3. Dell Latitude E6410 Hard Drive Replacement, Remove The Hard Drive: paso 3, imagen 1 de 2 Dell Latitude E6410 Hard Drive Replacement, Remove The Hard Drive: paso 3, imagen 2 de 2
    • Slide the hard drive out of the laptop. DO NOT TOUCH THE COMPONENTS OF THE DRIVE. Doing so could damage the drive. Protect yourself by touching an unpainted metal surface, such as the metal at the back of the computer. While you work, periodically touch an unpainted metal surface to dissipate static electricity.
    • Insert your new drive in to the hard drive caddy. Again, make sure you do not touch the components of the drive. After this, perform the steps above in reverse order.
    • After properly reassembling your device, your new hard drive should be installed. Great job.
Conclusión
To reassemble your device, follow these instructions in reverse order and power on your device.
2 personas más completaron esta guía.
Aaron Thomas
Miembro Desde 02/16/21
1,224 Reputación
10 Guías creadas
Equipo
RampUP America, Inc. Miembro de RampUP America, Inc.
Community
43 Miembros
1,985 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 11
Ultimos 30 días: 43
Todo El Tiempo: 2,841
