Saltar al contenido principal
Dell Latitude E6400 CPU Replacement
Qué necesitas
  1. Dell Latitude E6400 CPU Replacement, Battery Removal: paso 1, imagen 1 de 3 Dell Latitude E6400 CPU Replacement, Battery Removal: paso 1, imagen 2 de 3 Dell Latitude E6400 CPU Replacement, Battery Removal: paso 1, imagen 3 de 3
    • Disconnect AC power adaptor
    • Push battery release tabs inwards.
    • Slide the battery out of the computer.
  2. Dell Latitude E6400 CPU Replacement, Bottom Lid: paso 2, imagen 1 de 2 Dell Latitude E6400 CPU Replacement, Bottom Lid: paso 2, imagen 2 de 2
    • Remove the one 7.5 mm Phillips screw securing the bottom case.
    • Pull the bottom lid towards yourself to remove it.
  3. Dell Latitude E6400 CPU Replacement, Fan: paso 3, imagen 1 de 3 Dell Latitude E6400 CPU Replacement, Fan: paso 3, imagen 2 de 3 Dell Latitude E6400 CPU Replacement, Fan: paso 3, imagen 3 de 3
    • Remove the two 4.8mm Phillips screws securing the fan.
    • Disconnect the fan by pulling power cable straight up.
    • Lift the fan with your finger and slide it out towards the inside of the laptop.
  4. Dell Latitude E6400 CPU Replacement, Heat Sink: paso 4, imagen 1 de 2 Dell Latitude E6400 CPU Replacement, Heat Sink: paso 4, imagen 2 de 2
    • Remove the four Phillips screws securing the heat sink.
    • Using your finger gently lift and remove heat sink .
  5. Dell Latitude E6400 CPU Replacement: paso 5, imagen 1 de 1
    • Gently rotate left the locking screw to release CPU from its socket.
    • Lift the CPU straight up of it's socket.
Conclusión
D. K. Labudek
Miembro Desde 03/09/18
685 Reputación
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 7
Ultimos 30 días: 17
Todo El Tiempo: 435
