Saltar al contenido principal
Dell Latitude E6230 Battery Replacement
Qué necesitas
  1. Dell Latitude E6230 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Flip the laptop over, so that the latches next to the battery are visible.
  2. Dell Latitude E6230 Battery Replacement: paso 2, imagen 1 de 3 Dell Latitude E6230 Battery Replacement: paso 2, imagen 2 de 3 Dell Latitude E6230 Battery Replacement: paso 2, imagen 3 de 3
    • Pull the two latches next to the battery in opposite directions.
    • There should be a clicking noise made when this step is complete.
  3. Dell Latitude E6230 Battery Replacement: paso 3, imagen 1 de 2 Dell Latitude E6230 Battery Replacement: paso 3, imagen 2 de 2
    • Carefully lift the back of the battery and take it out of the laptop.
  4. Dell Latitude E6230 Battery Replacement: paso 4, imagen 1 de 2 Dell Latitude E6230 Battery Replacement: paso 4, imagen 2 de 2
    • Push the back of the new battery into the slot, and push downwards carefully.
    • You will hear a clicking noise when the battery is connected.
Linea de Meta
Kai Wang
Miembro Desde 04/05/22
109 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 14
Todo El Tiempo: 869
