Saltar al contenido principal
Dell Latitude E6230 12.5" HD (1366x768) Anti-Glare WLED-backlit Replacement
Qué necesitas
  1. Dell Latitude E6230 12.5" HD (1366x768) Anti-Glare WLED-backlit Replacement, Remove Battery: paso 1, imagen 1 de 2 Dell Latitude E6230 12.5" HD (1366x768) Anti-Glare WLED-backlit Replacement, Remove Battery: paso 1, imagen 2 de 2
    • Slide the release latches to unlock the battery.
    • Remove the battery from the computer.
  2. Dell Latitude E6230 12.5" HD (1366x768) Anti-Glare WLED-backlit Replacement, Removing the Display Bezel: paso 2, imagen 1 de 3 Dell Latitude E6230 12.5" HD (1366x768) Anti-Glare WLED-backlit Replacement, Removing the Display Bezel: paso 2, imagen 2 de 3 Dell Latitude E6230 12.5" HD (1366x768) Anti-Glare WLED-backlit Replacement, Removing the Display Bezel: paso 2, imagen 3 de 3
    • Pry the top edge of the display bezel.
    • Work your way along to the sides and bottom edge of the display bezel
    • Remove the display bezel from the display assembly
  3. Dell Latitude E6230 12.5" HD (1366x768) Anti-Glare WLED-backlit Replacement, Removing the Display Panel: paso 3, imagen 1 de 3 Dell Latitude E6230 12.5" HD (1366x768) Anti-Glare WLED-backlit Replacement, Removing the Display Panel: paso 3, imagen 2 de 3 Dell Latitude E6230 12.5" HD (1366x768) Anti-Glare WLED-backlit Replacement, Removing the Display Panel: paso 3, imagen 3 de 3
    • Remove the 6 (M2 x 3mm) screws that secure the display panel to the display assembly
    • Flip the display panel over
    • Peel off the LVDS cable connector tape and disconnect the LVDS cable from the display panel
    • Remove the display panel from the display assembly
Conclusión
alarson118
Miembro Desde 02/24/15
553 Reputación
3 Guías creadas
Equipo
Tech-zone Miembro de Tech-zone
Business
2 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 14
Todo El Tiempo: 203
