Saltar al contenido principal
Dell Latitude E5500 Wireless Card Replacement
Qué necesitas
  1. Dell Latitude E5500 Wireless Card Replacement, Wireless Card: paso 1, imagen 1 de 1
    • Unscrew the single 3.5mm Phillips #1 screw that holds on the bottom plate of the device.
  2. Dell Latitude E5500 Wireless Card Replacement: paso 2, imagen 1 de 2 Dell Latitude E5500 Wireless Card Replacement: paso 2, imagen 2 de 2
    • Place your hands on the plate and pull it toward yourself.
    • The plate will pop out of place and may then be removed.
  3. Dell Latitude E5500 Wireless Card Replacement: paso 3, imagen 1 de 2 Dell Latitude E5500 Wireless Card Replacement: paso 3, imagen 2 de 2
    • The wireless card is located near the front of the device, and is the expansion card with three antennas attached to it.
  4. Dell Latitude E5500 Wireless Card Replacement: paso 4, imagen 1 de 1
    Herramienta utilizada en este paso:
    • Remove the wires connecting the card to the laptop with a pair of tweezers.
  5. Dell Latitude E5500 Wireless Card Replacement: paso 5, imagen 1 de 1
    • Unscrew the 4mm Phillips #1 screw that secure the card in place.
  6. Dell Latitude E5500 Wireless Card Replacement: paso 6, imagen 1 de 2 Dell Latitude E5500 Wireless Card Replacement: paso 6, imagen 2 de 2
    • After completing steps 4 & 5, the card will lift up at an angle as shown.
    • Once the card has popped out of place, it can be gently removed.
Conclusión
3 personas más completaron esta guía.
Equipo
UMass Dartmouth, Team 2-4, Isaacson Fall 2016 Miembro de UMass Dartmouth, Team 2-4, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G4
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 36
Ultimos 30 días: 52
Todo El Tiempo: 1,376
