Saltar al contenido principal
Dell Latitude E5500 Thermal Compound Replacement
Qué necesitas
  1. Dell Latitude E5500 Thermal Compound Replacement, Cooling Fan: paso 1, imagen 1 de 1
    • Unscrew the single 3.5mm Phillips #1 screw that holds on the bottom plate of the device.
  2. Dell Latitude E5500 Thermal Compound Replacement: paso 2, imagen 1 de 2 Dell Latitude E5500 Thermal Compound Replacement: paso 2, imagen 2 de 2
    • Place your hands on the plate and pull it toward yourself.
    • The plate will pop out of place and may then be removed.
  3. Dell Latitude E5500 Thermal Compound Replacement: paso 3, imagen 1 de 1
    • The cooling fan is located near the edge of the device, on the side with the vent, and is contained within a plastic shroud.
  4. Dell Latitude E5500 Thermal Compound Replacement: paso 4, imagen 1 de 3 Dell Latitude E5500 Thermal Compound Replacement: paso 4, imagen 2 de 3 Dell Latitude E5500 Thermal Compound Replacement: paso 4, imagen 3 de 3
    • Unscrew the two 9mm Phillips #1 screws that secure the fan in place.
    • Disconnect the fan header from the motherboard of the laptop.
    • The fan header has many small wires sleeved together. To avoid ripping the wires out of the connector, wiggle the connector out of place instead of pulling straight up on it.
  5. Dell Latitude E5500 Thermal Compound Replacement: paso 5, imagen 1 de 1
    • Remove the fan from its housing.
    • The fan may be difficult to get out of the housing, as it is surrounded on three sides by the housing itself and the heatsink. It is not glued or taped in, however, so you can gently pull the cord you just disconnected up to remove the fan from the housing without risk of damaging the cord.
  6. Dell Latitude E5500 Thermal Compound Replacement, Thermal Compound: paso 6, imagen 1 de 2 Dell Latitude E5500 Thermal Compound Replacement, Thermal Compound: paso 6, imagen 2 de 2
    • The system's heatsink is the copper pipe and large metal assembly held down by five screws.
    • Remove the five Phillips #1 screws in the order numbered on the metal assembly.
  7. Dell Latitude E5500 Thermal Compound Replacement: paso 7, imagen 1 de 3 Dell Latitude E5500 Thermal Compound Replacement: paso 7, imagen 2 de 3 Dell Latitude E5500 Thermal Compound Replacement: paso 7, imagen 3 de 3
    • The screws are self-retaining, meaning they will stay connected to the heatsink and will not fall out from the assembly.
    • After all screws have been unscrewed, the heatsink can be removed.
  8. Dell Latitude E5500 Thermal Compound Replacement: paso 8, imagen 1 de 1
    • The thermal compound is the gray material that sits on the heatsink and CPU surfaces. In order to apply new compound, the old compound must be removed
    • If the thermal compound is hard or crusty, the compound is either very old or is low quality.
  9. Dell Latitude E5500 Thermal Compound Replacement: paso 9, imagen 1 de 3 Dell Latitude E5500 Thermal Compound Replacement: paso 9, imagen 2 de 3 Dell Latitude E5500 Thermal Compound Replacement: paso 9, imagen 3 de 3
    • Use a cotton ball or swab and apply rubbing alcohol until it is moist but not dripping.
    • Scrub the heatsink surface with the cotton ball until all thermal compound is removed.
    • If the thermal compound is hard or crusty, a cotton swab will work better at removing it than a cotton ball.
  10. Dell Latitude E5500 Thermal Compound Replacement: paso 10, imagen 1 de 2 Dell Latitude E5500 Thermal Compound Replacement: paso 10, imagen 2 de 2
    • Reapply alcohol to a new cotton ball or cotton swab and repeat Step 9 for the CPU surface.
    • If you spill the alcohol onto the CPU or the rest of the motherboard, wait for it to evaporate fully before turning the system on.
  11. Dell Latitude E5500 Thermal Compound Replacement: paso 11, imagen 1 de 3 Dell Latitude E5500 Thermal Compound Replacement: paso 11, imagen 2 de 3 Dell Latitude E5500 Thermal Compound Replacement: paso 11, imagen 3 de 3
    • Apply the new thermal compound onto the surface of the CPU.
    • For this application, use a blob about the size of a grain of rice.
    • Using too much compound will not adversely affect cooling, but will be wasteful and spill over to the surface of the CPU and can damage the computer. However, using too little will result in poor contact between the heatsink and CPU and result in poor cooling performance.
Conclusión
To reassemble your device, follow steps 1-7 in reverse order.
4 personas más completaron esta guía.
Equipo
UMass Dartmouth, Team 2-4, Isaacson Fall 2016 Miembro de UMass Dartmouth, Team 2-4, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G4
Miembros de 3
5 Guías creadas
Un comentario
Great post and i followed the mentioned steps. Now, my cpu heat rate low down to 20%. thanks for such a wonderful article. Happy Fathers Day to all of you.
Check Results - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 36
Todo El Tiempo: 2,075
