Saltar al contenido principal
Dell Latitude E5500 RAM Replacement
Qué necesitas
  1. Dell Latitude E5500 RAM Replacement, RAM: paso 1, imagen 1 de 1
    • Unscrew the single 3.5mm Phillips #1 screw that holds on the bottom plate of the device.
  2. Dell Latitude E5500 RAM Replacement: paso 2, imagen 1 de 2 Dell Latitude E5500 RAM Replacement: paso 2, imagen 2 de 2
    • Place your hands on the plate and pull it toward yourself.
    • The plate will pop out of place and may then be removed.
  3. Dell Latitude E5500 RAM Replacement: paso 3, imagen 1 de 1
    • The RAM sticks are located near the center of the device, and are arranged one on top of the other.
  4. Dell Latitude E5500 RAM Replacement: paso 4, imagen 1 de 2 Dell Latitude E5500 RAM Replacement: paso 4, imagen 2 de 2
    • Locate the two dislocating tabs on each side of the stick and place your fingers on the tabs.
    • Pull the tabs away from the stick to pop it out of place.
    • Notice the angle it rests at after the tabs have been opened. This is important for installation of new RAM.
    • Once the RAM stick has popped out of place, it can be gently removed.
  5. Dell Latitude E5500 RAM Replacement: paso 5, imagen 1 de 3 Dell Latitude E5500 RAM Replacement: paso 5, imagen 2 de 3 Dell Latitude E5500 RAM Replacement: paso 5, imagen 3 de 3
    • If necessary, repeat this process with the second RAM stick that lies beneath the first one.
Conclusión
To reassemble your device, install the new stick(s) and follow these instructions in reverse order.
4 personas más completaron esta guía.
Evan Eldridge
Miembro Desde 10/20/16
215 Reputación
1 Guía escrita
Equipo
UMass Dartmouth, Team 2-4, Isaacson Fall 2016 Miembro de UMass Dartmouth, Team 2-4, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G4
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 4
Ultimos 30 días: 9
Todo El Tiempo: 2,156
