Saltar al contenido principal
Dell Latitude E5500 Cooling Fan Replacement
Qué necesitas
  1. Dell Latitude E5500 Cooling Fan Replacement, Cooling Fan: paso 1, imagen 1 de 1
    • Unscrew the single 3.5mm Phillips #1 screw that holds on the bottom plate of the device.
  2. Dell Latitude E5500 Cooling Fan Replacement: paso 2, imagen 1 de 2 Dell Latitude E5500 Cooling Fan Replacement: paso 2, imagen 2 de 2
    • Place your hands on the plate and pull it toward yourself.
    • The plate will pop out of place and may then be removed.
  3. Dell Latitude E5500 Cooling Fan Replacement: paso 3, imagen 1 de 1
    • The cooling fan is located near the edge of the device, on the side with the vent, and is contained within a plastic shroud.
  4. Dell Latitude E5500 Cooling Fan Replacement: paso 4, imagen 1 de 3 Dell Latitude E5500 Cooling Fan Replacement: paso 4, imagen 2 de 3 Dell Latitude E5500 Cooling Fan Replacement: paso 4, imagen 3 de 3
    • Unscrew the two 9mm Phillips #1 screws that secure the fan in place.
    • Disconnect the fan header from the motherboard of the laptop.
    • The fan header has many small wires sleeved together. To avoid ripping the wires out of the connector, wiggle the connector out of place instead of pulling straight up on it.
  5. Dell Latitude E5500 Cooling Fan Replacement: paso 5, imagen 1 de 1
    • Remove the fan from its housing.
    • The fan may be difficult to get out of the housing, as it is surrounded on three sides by the housing itself and the heatsink. It is not glued or taped in, however, so you can gently pull the cord you just disconnected up to remove the fan from the housing without risk of damaging the cord.
Conclusión
2 personas más completaron esta guía.
Equipo
UMass Dartmouth, Team 2-4, Isaacson Fall 2016 Miembro de UMass Dartmouth, Team 2-4, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G4
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 13
Todo El Tiempo: 1,522
