Saltar al contenido principal
Dell Latitude E5500 CD ROM Drive Replacement
Qué necesitas
  1. Dell Latitude E5500 CD ROM Drive Replacement, CD ROM Drive: paso 1, imagen 1 de 1
    • Place the front of the laptop on the table so that the hinges are facing away from yourself.
  2. Dell Latitude E5500 CD ROM Drive Replacement: paso 2, imagen 1 de 1
    • Remove the screw located in the red circle shown.
  3. Dell Latitude E5500 CD ROM Drive Replacement: paso 3, imagen 1 de 1
    • Apply a small amount of pressure and slide the cover towards yourself in the direction indicated.
  4. Dell Latitude E5500 CD ROM Drive Replacement: paso 4, imagen 1 de 2 Dell Latitude E5500 CD ROM Drive Replacement: paso 4, imagen 2 de 2
    • Locate the slot for the CD ROM ejector found inside the red box shown.
  5. Dell Latitude E5500 CD ROM Drive Replacement: paso 5, imagen 1 de 2 Dell Latitude E5500 CD ROM Drive Replacement: paso 5, imagen 2 de 2
    • Using a #2 Phillip's head screwdriver, push the CD ROM ejector to the left.
    • Once the CD ROM clicks out, carefully slide it out of the laptop.
Conclusión
To reassemble your device, follow these instructions in reverse order using your new CD Rom.
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 21
Ultimos 30 días: 22
Todo El Tiempo: 676
