Introducción
This guide will demonstrate how to replace the hard drive on your Latitude E5430.
  1. Slide the two notches outward. Lift the battery outward and pull.
    • Slide the two notches outward. Lift the battery outward and pull.
  2. Remove two Phillips head screws from the bottom cover.
    • Remove two Phillips head screws from the bottom cover.
  3. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  4. Remove the four Phillips head screws from the hard drive caddy.
    • Remove the four Phillips head screws from the hard drive caddy.
    • System memory (RAM) is located here.
    • Low profile WLAN card
    • Various components can be replaced from this stage.
  5. Remove the four Phillips head screws surrounding the hard drive in the caddy.
    • Remove the four Phillips head screws surrounding the hard drive in the caddy.
    • There are two more screws on the other side of the hard drive.
  6. Congratulations, you've done it!
    • Congratulations, you've done it!
Conclusión
After you have installed your new hard drive or SSD, repeat the process in reverse.
Sam
Miembro Desde 24/02/17
402 Reputación
3 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 8
Últimos 30 Días: 23
Todo El Tiempo: 111
