Saltar al contenido principal
Dell Latitude E5410 keyboard Replacement
Qué necesitas
  1. Dell Latitude E5410 keyboard Replacement, Dell Latitude E5410 keyboard: paso 1, imagen 1 de 1
    • Position laptop so that the LCD screen is aligned directly flat and parallel to the keyboard section of the laptop.
  2. Dell Latitude E5410 keyboard Replacement: paso 2, imagen 1 de 1
    • Use the iFix it Opening Tool to remove the flat section located directly above the keyboard, as seen in picture.
  3. Dell Latitude E5410 keyboard Replacement: paso 3, imagen 1 de 1
    • Locate two internal screws (pictured) under removed section.
    • Use the Phillips screwdriver to remove both screws.
    • The screw in the middle is 3.85mm and the screw on the left is 8.66mm.
  4. Dell Latitude E5410 keyboard Replacement: paso 4, imagen 1 de 1
    • Firmly grip the upper section of the keyboard.
    • Pull on the keyboard in an upwards motion.
    • The keyboard should be successfully removed.
Conclusión
3 personas más completaron esta guía.
Un comentario
thanks man but its super easy not moderat i have 16 years old and i remove my keybord...
ZendomXGamer ZXG - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 11
Ultimos 30 días: 14
Todo El Tiempo: 5,326
